Prośba o analizę skanu vcds
pavloroz
Post autor: pavloroz »
Przeskanowałem swego tourana i proszę o analizę bo są jakieś błedy.
Monday,03,September,2012,17:52:21:37412
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 37 42 44 46 52 56 62 69 72 76
77
VIN: WVGZZZ1TZ6W209938 Mileage: 161420km/100301miles
15-Airbags -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
77-Telephone -- Status: OK 0000
Part No SW: 03G 906 021 HN HW: 03G 906 021 HN
Component: R4 2,0L EDC G000SG 9097
Revision: --H02--- Serial number: VWZ7Z0F7039755
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 72E1AB6C143F
2 Faults Found:
001681 - Fan 1 Control Circuit: Short to GND
P0691 - 000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 161309 km
Time Indication: 0
Date: 2000.00.00
Time: 12:04:43
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00001100
Temperature: 14.4°C
Duty Cycle: 9.7 %
005660 - Glowplug for Cylinder 3 (Q12): Open Circuit
P161C - 000 - -
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 161309 km
Time Indication: 0
Date: 2000.00.00
Time: 12:16:18
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00001100
Temperature: 14.4°C
Bin. Bits: 00110000
Readiness: 0 0 0 0 0
Revision: 00H11001
Coding: 0023238
Shop #: WSC 01324 785 00200
VCID: 73EFAE686B25
No fault code found.
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 70E5A1641A33
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005963469
Coding: 018B8F2100040F0000120C000000000000097F075C
VCID: 2B5F7608F395
Part No: 1T0 955 119 D
Component: Wischer 220606 020 0501
Coding: 00038805
Shop #: WSC 01324
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0KDLX-
Coding: 0012338
VCID: 356B507025D1
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 636 0070
Coding: 0000042
VCID: 74EDAD746E2B
Part No: 1T0 920 872 F
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0007101
Shop #: WSC 00012 000 00000
VCID: 37775A783FDD
Part No: 1K0 815 071 R
Component: Zuheizer 050 2302
Coding: 0000011
VCID: 346D6D742EAB
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 310010662413F9
Coding: 3D3F57C807008002
VCID: 2C5D7514F69B
Component: IMMO VDD 4312
VCID: 37775A783FDD
Address 37: Navigation Labels: 1K0-919-887-MFD2.lbl
Part No: 1K0 919 887 F
Component: Navigation 0030
Coding: 0000101
VCID: 3C7D455406FB
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2301
Coding: 0000245
VCID: 3669577C38D7
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.071 H07 1806
VCID: 346D6D742EAB
Part No SW: 1K0 959 433 CB HW: 1K0 959 433 CB
Component: KSG PQ35 G2 020 0202
Coding: 009002085103087F2D06840560084F01E0BD00
VCID: 72E1AB6C143F
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000245
VCID: 37775A783FDD
Address 56: Radio Labels: 1K0-035-095.lbl
Part No: 1K0 035 095 E
Component: Radio 0030
Coding: 0042402
VCID: 27578A38EF7D
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2428
Coding: 0000144
VCID: 32616B6CD4BF
Address 69: Trailer
Cannot be reached
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
VCID: 336F6E682BA5
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 02 Einparkhilfe 0101
VCID: 2D5B7810CD81
Address 77: Telephone Labels: Redir Fail!
Part No: 1K0 035 729 E
Component: CIB PAH HW 203 SW 0308
Coding: 0000364
VCID: 2B5F7608F395
Mam rozumieć,że błędy po skasowaniu błedów i ponownym skanowaniu :mrgreen:
pavloroz pisze:005660 - Glowplug for Cylinder 3 (Q12): Open Circuit
Sprawdź świecę żarowa lub okablowanie świecy 3- cylindra
Ten drugi to zwarcie do masy wentylatora chłodnicy. Tego nie jestem pewien.. Sprawdź ich działanie
pavloroz
O świecy wiedziałem już wcześniej miałem ją wymienic ale drugi to jak mam sprawdzic sorry za pytania ale jestem początkujący. Z góry dziękuję za rady.
shaman82
Auto:: 1T1 BXF '06
Imię:: Pablo
Post autor: shaman82 »
pavloroz pisze:ale drugi to jak mam sprawdzic sorry za pytania ale jestem początkujący. Z góry dziękuję za rady.
Jak poszukasz to znajdziesz kilka tematów na naszym forum dotyczących wentylatorów na chłodnicy.
Przykładowo: http://touranklub.pl/forum/viewtopic.php?t=1908&postdays=0&postorder=asc&start=0
Spróbuj! Wszyscy korzystamy z wyszukiwarki ;)
