Problem ze skanem
rafi
Problem ze skanem
Post autor: rafi »
Panowie, mam problem z odczytaniem bledow w samochodzie audi 1.8 t. Mianowicie po podlaczeniu vcds-a kontrolka nie zapala sie na kolor zielony. Czy jest mozliwe uszkodzenie gniazda diagnostycznego? Wrzucam to co udalo mi sie zeskanowac i prosilbym o rozszyfrowanie. Druga sprawa, jak przeprowadzic adaptacje przepustnicy, bo zostala wymieniona.
VCDS Version: Beta 11.2.0
Data version: 20110305
Sunday,09,December,2012,21:15:11:10074
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Mileage: 192080km/119352miles
Address 01: Engine Labels: None
Part No: 4B0 906 018 AA
Component: 1.8L R4/5VT 0006
Coding: 04502
Shop #: WSC 00082
VCID: 60CBA4B3C883
2 Faults Found:
17987 - Throttle Actuator (J338): Adaptation Not Started
P1579 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 D
Component: ABS/ESP front D36
Coding: 06275
Shop #: WSC 02325
VCID: 346318E32CFB
1 Fault Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 J
Component: A6-Klimavollautomat D64
Coding: 00040
Shop #: WSC 02325
VCID: 214DE1B78309
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4B0 959 655 E
Component: Airbag Front+Kopf 2001
Coding: 00406
Shop #: WSC 00000
VCID: 326F1EFBD6EF
No fault code found.
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 900 G
Component: C5-KOMBIINSTR. VDO D11
Coding: 00144
Shop #: WSC 00000
VCID: 214DE1B78309
Component: AUZ7Z0X1328452
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0X1328452
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 D
Component: Zentralverriegelung D33
Coding: 04673
Shop #: WSC 02325
VCID: 2A5F069BFE3F
3 Faults Found:
01560 - Passenger Door
59-00 - Can't Unlock
01562 - Right Rear Door
59-10 - Can't Unlock - Intermittent
61-00 - Won't De-Safe
Udalo mi sie wykasowac czesc bledow ktore juz ne powrocily
Sunday,09,December,2012,21:24:26:10074
75 76 77
Coding: 04502
Shop #: WSC 00082
VCID: 60CBA4B3C883
1 Fault Found:
P1579 - 35-00 - -
Coding: 06275
Shop #: WSC 02325
VCID: 346318E32CFB
Coding: 00040
Shop #: WSC 02325
VCID: 214DE1B78309
Coding: 00406
Shop #: WSC 00000
VCID: 326F1EFBD6EF
Coding: 00144
Shop #: WSC 00000
VCID: 214DE1B78309
Coding: 04673
Shop #: WSC 02325
VCID: 2A5F069BFE3F
Porsze o pomoc.
VW Touran 1,9 TDI 2005r. DSG
ADAPTACJA NASTAWNIKA PRZEPUSTNICY
Poniżej opisano sposób przeprowadzenia adaptacji nastawnika przepustnicy.
Procedura dotyczy wielu pojazdów VW/AUDI/SEAT/SKODA wyposażonych zarówno
w przepustnicę typu Drive-By-Wire (sterowaną całkowicie elektrycznie) jak też
posiadających przepustnicę sterowaną za pomocą tradycyjnej linki połączonej z
pedałem gazu. W tym ostatnim przypadku (gdzie między pedałem gazu i
przepustnicą jest linka), adaptacja przepustnicy może być przeprowadzona pod
warunkiem, że pojazd nie jest wyposażony w zawór regulacji biegu jałowego (ISV).
Pojazdy wyposażone w ten zawór nie posiadają elektrycznych silniczków sterujących
pracą przepustnicy
Oto wybrane przykłady sytuacji, po których powinno się przeprowadzić
omawianą tu procedurę:
► Akumulator pojazdu został odłączony, ponownie podłączony lub się rozładował.
► Sterownik silnika został wymieniony na nowy lub wymontowany i ponownie
zainstalowany.
► Zespół przepustnicy został przeczyszczony, wymieniony na nowy lub
wymontowany i ponownie zainstalowany.
► Pedał przyśpieszenia został wymieniony na nowy lub wymontowany i ponownie
zainstalowany.
Aby prawidłowo przeprowadzić procedurę adaptacji przepustnicy, muszą
zostać spełnione następujące warunki:
► Brak błędów a pamięci sterownika silnika.
► Napięcie akumulatora przynajmniej 11.5 V
► Przepustnica w pozycji: "Bieg jałowy"
► Przepustnica czysta!
► Wyłączone urządzenia elektryczne pobierające dużą ilość energii elektrycznej
(ogrzewanie szyb, foteli, klimatyzacja, oświetlenie zewnętrzne)
► Temperatura płynu chłodzącego pomiędzy 5 a 95ºC
► W niektórych "mniejszych" silnikach (1.0-1.4 ccm np. VW Lupo, Polo...) przed
właściwą procedurą adaptacji przepustnicy, należy wykasować wcześniej wyuczone
wartości zapisane w sterowniku silnika. Robi się to zapisując wartość "0" na
"zerowym" kanale adaptacji (00).
PROCEDURA ADAPTACJI PRZEPUSTNICY W POJAZDACH Z TRADYCYJNĄ
LINKĄ GAZU (ale bez zaworu regulacji biegu jałowego):
Zapłon włączony, silnik nie pracuje!
[Wybór]
[01 - Silnik]
[Bloki pomiarowe - 08]
Wybierz grupę "098" (lub grupę "001" w niektórych pojazdach wyposażonych w
sterowniki SIMOS i Marelli np. silniki ADY i AEE).
[Idź!]
[Przełącz na Nastawy - 04]
Po przełączeniu na Nastawy podstawowe w górnym, prawym polu ekranu pojawi się
informacja: "Adapt. trwa" i rozpocznie się proces adaptacji. Można będzie również
usłyszeć pracę przepustnicy i zauważyć jak zmieniają się pewne wartości
wyświetlane przez program VAG-COM. System należy pozostawić w nastawach
podstawowych przez około 30 sekund, po czym można ponownie przełączyć na :
PODCZAS WYKONYWANIA POWYŻSZEJ PROCEDURY NIE WOLNO DOTYKAÆ PEDAŁU GAZU
I SILNIK NIE MOŻE BYÆ URUCHOMIONY.
PROCEDURA ADAPTACJI PRZEPUSTNICY W POJAZDACH Z PRZEPUSTNICĄ DBW (Sprawdź
czy komunikacja z silnikiem jest realizowana przez protokół KWP-1281 - informacja widoczna w
lewym, górnym rogu ekranu "Odczyt z sterownika").
[Wybór]
[01 - Silnik]
Wybierz grupę "060"
[Idź!]
[Bloki pomiarowe – 08]
PEDAŁU GAZU I SILNIK NIE MOŻE BYÆ URUCHOMIONY.
DBW (protokół KWP-2000) (Sprawdź czy komunikacja z silnikiem jest realizowana
przez protokół KWP-2000 - informacja widoczna w lewym, górnym rogu ekranu
"Odczyt z sterownika"). Niektóre przykłady pojazdów, w których sterownik silnika
wykorzystuje KWP-2000 ( rok prod. 2002 + ): / A4 / Passat / Touareg.
[Wybór]
[01 - Silnik]
[Nastawy podst. - 04]
Wybierz grupę "060".
[Idź!]
Na górze ekranu powinna pojawić się informacja: Nastawy podstawowe: OFF.
Kliknij przycisk: [ON/OFF/Dalej] Powinien pojawić się komunikat: Nastawy
podstawowe: ON. Po przełączeniu na Nastawy podstawowe w górnym, prawym
polu ekranu pojawi się informacja: "Adapt. trwa" i rozpocznie się proces adaptacji.
Można będzie również usłyszeć pracę przepustnicy i zauważyć jak zmieniają się
pewne wartości wyświetlane przez program VAG-COM. System należy pozostawić w
nastawach podstawowych przez około 30 sekund, po czym ponownie kliknąć:
[ON/OFF/Dalej] wyłączając w ten sposób Nastawy podstawowe. Na górze ekranu
[Gotowe, powrót]
rafi
Post autor: rafi »
jeżu super, wielkie dzieki, ale czy da sie przeprowadzic adaptacje przy zlym polaczeniu can? Takie komunikaty mi wyskakuja i nic sie nie da zrobic K1: OK K2: OK CAN: Not Ready
A czy to Audi to jest już po Canie? Bo nie napisałeś rocznika..... Chyba nie... Ale skan widzę że da się zrobić?
rafi
Post autor: rafi »
No wlasnie mam problem z polaczeniem, caly czas wyskakuje can - not ready i nie wiem co mam zrobic. Rocznika nie pamietam, jutro bede wiedzial.
QQRYDZA
Auto:: 1,9tdi
Imię:: dar
Post autor: QQRYDZA »
Zainstaluj jeszcze raz program.
[you]--->Niebieski
ZWzPD
rafi
Post autor: rafi »
QQRYDZA pisze:Zainstaluj jeszcze raz program.
Przed podlaczeniem sie do audi, skanowalem touran kolegi i bylo wszystko super.
admin
Imię:: Maciek
Post autor: admin »
rafi pisze:jeżu super, wielkie dzieki, ale czy da sie przeprowadzic adaptacje przy zlym polaczeniu can? Takie komunikaty mi wyskakuja i nic sie nie da zrobic K1: OK K2: OK CAN: Not Ready
A6 C5 nie jest na CANie i zawsze Ci się tak wyświetli.
kristouran
Re: Problem ze skanem
Post autor: kristouran »
jeżu pisze:ADAPTACJA NASTAWNIKA PRZEPUSTNICY
pracą przepustnicy
zainstalowany.
zainstalowany.
[Wybór]
[01 - Silnik]
[Idź!]
[Wybór]
[01 - Silnik]
Wybierz grupę "060"
[Idź!]
[Wybór]
[01 - Silnik]
[Idź!]
[Gotowe, powrót]
jak zrobić adaptację przepustnicy VCDS 15.7 ? Nie ma tu bloków pomiarowych.
A w jakim aucie, jaki silnik?
kristouran
wesol pisze:A w jakim aucie, jaki silnik?
Passat B7 1.6tdi
Ta procedura dotyczy silników benzynowych... Przepustnica w dieslu służy do zgaszenia auta..
Diesle nie maja przepustnicy. To klapa gaszaca. Przepustnica to jak sama nazwa wskazuje ruguluje przepuszczanie czegos. W przypadku silnikow ZI przeplyw powietrza lub powietrza i paliwa. Plynna regulacja. Diesel czyli ZS nie ma stanow posrednich tylko klapa otwarta lub zamknieta calkowicie. No i diesel ma ja otwarta caly czas tylko w momencie gaszenia silnika czyli engine off ta klapa zamyka sie na zdaje sie 4 sekundy. Brak stanow posrednich.
kristouran
Ostatnio zmieniony ndz lis 19, 2017 19:44 przez kristouran, łącznie zmieniany 1 raz.
Link nie trybi
