Analiza loga
pavloroz
Analiza loga
Od kilku dni mój Touran inaczej pali tzn podczas odpalania trzęsie silnikiem jakieś 4 sekundy póżniej się uspokaja, po za tym spadła moc, wciskam gaz a on bardzo wolno reaguje, no i spalanie na biegu jałowym tylko 0,4 z klimą a zawsze miałem 0,6. Zrobiłem skan VCDS-em 11.11.3 nie było żadnych błędów związanych z silnikiem. Przeprowadziłem diagnozę pompowtrysków ale ciężko mi stwierdzic czy coś jest nie tak. Czy ktoś z pomógł by mi w analizie.
03G 906 021 HN,,R4 2.0L EDC G000SG 9097,
,Group A:,'018,,,,Group B:,'023,,,,Group C:,'013
,,Injector Status,Injector Status,Injector Status,Injector Status,,Switch Time Deviat.,Switch Time Deviat.,Switch Time Deviat.,Switch Time Deviat.,,Injection Quantity,Injection Quantity,Injection Quantity,Injection Quantity
,TIME,Cylinder 1,Cylinder 2,Cylinder 3,Cylinder 4,TIME,Cylinder 1,Cylinder 2,Cylinder 3,Cylinder 4,TIME,Deviation Cyl. 1,Deviation Cyl. 2,Deviation Cyl. 3,Deviation Cyl. 4
Marker,STAMP,,,,,STAMP,,,,,STAMP, mg/str, mg/str, mg/str, mg/str
,0.41,0.0,0.0,0.0,0.0,0.11,1.0,-22.0,-13.0,-3.0,0.25,-0.68,-0.24,0.42,0.49
,0.81,0.0,0.0,0.0,0.0,0.54,1.0,-19.0,-18.0,1.0,0.68,-0.68,-0.24,0.42,0.49
,1.23,0.0,0.0,0.0,0.0,0.95,1.0,-18.0,-18.0,1.0,1.09,-0.68,-0.24,0.42,0.49
,1.65,0.0,0.0,0.0,0.0,1.36,1.0,-21.0,-14.0,-1.0,1.51,-0.68,-0.24,0.42,0.49
,2.06,0.0,0.0,0.0,0.0,1.78,1.0,-20.0,-14.0,-1.0,1.91,-0.68,-0.24,0.42,0.49
,2.47,0.0,0.0,0.0,0.0,2.20,1.0,-20.0,-13.0,-3.0,2.33,-0.68,-0.24,0.42,0.49
,2.89,0.0,0.0,0.0,0.0,2.61,1.0,-20.0,-16.0,-1.0,2.75,-0.68,-0.24,0.42,0.49
,3.31,0.0,0.0,0.0,0.0,3.01,2.0,-22.0,-16.0,0.0,3.16,-0.68,-0.24,0.42,0.49
,3.72,0.0,0.0,0.0,0.0,3.43,2.0,-22.0,-15.0,-1.0,3.57,-0.68,-0.24,0.42,0.49
,4.15,0.0,0.0,0.0,0.0,3.86,2.0,-24.0,-15.0,-2.0,4.01,-0.68,-0.24,0.42,0.49
,4.57,0.0,0.0,0.0,0.0,4.30,2.0,-24.0,-14.0,-3.0,4.44,-0.68,-0.24,0.42,0.49
,5.00,0.0,0.0,0.0,0.0,4.70,2.0,-20.0,-14.0,0.0,4.86,-0.68,-0.24,0.42,0.49
,5.42,0.0,0.0,0.0,0.0,5.13,2.0,-23.0,-16.0,-1.0,5.27,-0.68,-0.24,0.42,0.49
,5.83,0.0,0.0,0.0,0.0,5.55,2.0,-22.0,-19.0,-6.0,5.69,-0.68,-0.24,0.42,0.49
,6.27,0.0,0.0,0.0,0.0,5.98,2.0,-22.0,-18.0,-3.0,6.13,-0.68,-0.24,0.42,0.49
,6.69,0.0,0.0,0.0,0.0,6.41,2.0,-24.0,-18.0,-5.0,6.56,-0.68,-0.24,0.42,0.49
,7.11,0.0,0.0,0.0,0.0,6.83,2.0,-24.0,-17.0,-2.0,6.96,-0.68,-0.24,0.42,0.49
,7.52,0.0,0.0,0.0,0.0,7.25,2.0,-20.0,-17.0,0.0,7.38,-0.68,-0.24,0.42,0.49
,7.94,0.0,0.0,0.0,0.0,7.67,1.0,-20.0,-16.0,-1.0,7.80,-0.68,-0.24,0.42,0.49
,8.37,0.0,0.0,0.0,0.0,8.07,1.0,-20.0,-16.0,-3.0,8.23,-0.68,-0.24,0.42,0.49
,8.81,0.0,0.0,0.0,0.0,8.52,5.0,-21.0,-19.0,-3.0,8.65,-0.68,-0.24,0.42,0.49
,9.22,0.0,0.0,0.0,0.0,8.95,2.0,-20.0,-18.0,-2.0,9.10,-0.68,-0.24,0.42,0.49
,9.64,0.0,0.0,0.0,0.0,9.38,2.0,-19.0,-17.0,-2.0,9.52,-0.68,-0.24,0.42,0.49
,10.07,0.0,0.0,0.0,0.0,9.78,2.0,-19.0,-17.0,0.0,9.93,-0.68,-0.24,0.42,0.49
pavloroz
Dzięki moj log na stronie http://vaglog.rtnet.pl/pavlor_126848.html może teraz będzie łatwiej z analizować go.
collega
- Auto:: Touran 1.9 TDI BXE 2006
Te czasy pompek sa troche dziwne u mnie wyglada to tak -18 -19 -20 -21 znajomy ma w passacie nowe pomki (wymienial wszystkie na akcji serwisowej rok temu ) i u niego na kazdej pompce jest wartosc -21
Nie wiem czy to ma znaczenie ale tak jak mowie porownujac to do moich czy tez mojego znajomego wyglada to dosc dziwnie
