Zestaw głośnomówiący BURY C9056 smart
Post autor: LYJO »
Panowie mam następujące pytanko o ten zestaw głośnomówiący.
Czy ktoś kiedyś sparował więcej niż 1 telefon?
Ten zestaw potrafi podobno 10 telefonów sparować.
Niestety ja nie potrafię uaktywnić funkcji MULTIPOINT (tzn zaznaczyć ja ptaszkiem, żeby działała).
Próbowałem już z 5 telefonami i pojedyńczo się łączą i jest ok. Niestety, żeby dodać do listy telefonów w urządzeniu już lipa bo wspomniana opcja MULTIPOINT jest nie aktywna :(
Re: Zestaw głośnomówiący BURY C9056 smart
The last menu item in the Bluetooth menu is the
Multipoint
function. This function can only be activated if at least two mobile phone signatures are included in the list of telephones. Otherwise the function is not available and the selection field during operation via the Touch screen is inactive.
Using the Multipoint function, you can operate two mobile telephones on the HFCK in hands-free mode
at the same time. The primary mobile phone takes priority, which means that only its telephone books,
call lists, voice memos, SMS and possible emails are loaded and ready in the memory of the HFCK. This
is similar to the situation as though only one mobile phone were connected with the HFCK. If a call is
received on the secondary mobile phone, this call will also be handled via the HFCK. The display in
forms you accordingly as to which mobile is receiving the call (the first / second telephone).
If a call is received by both mobile phones at the same time, preference is given to the primary mobile phone. You will be displayed the incoming call on the other mobile after accepting or declining the
first call. You are then able to end the first call at short notice and to also decline the second call (pressing to the right of the red receiver both times), or to end the first call and to accept the second call
directly (press the symbol on the left). Holding the first call isn’t possible, as the calls are not being
made on the same telephone number. The conference mode which is described in the instructions
below is not possible between the two mobile phones.
If two or more mobile phone signatures are saved and the Multipoint function is activated, then the
mobile phones will be sought and connected in the order in which they are listed in the telephones list position 1 and position 2. In addition to the first telephone that is connected, you will then also be
shown the second telephone in the main menu.
If a number of signatures from different mobile phones have been saved (from several different drivers) it may be the case that their order does not suit your requirements. To be able to define both
telephones and their order for the multipoint function, you can set one mobile phone as standard (as
telephone 1) and another mobile phone as telephone 2. If you do not set the second telephone then
the HFCK will complete a full search of the telephones list twice over. If the HFCK does not find a second active telephone (because the Bluetooth function has not been activated, for instance), you must
either connect the second telephone manually via the telephone list, or deactivate the multipoint function and then activate it again
Post autor: LYJO »
Nie za bardzo kumam o co loto w 2 i 3 zdaniu.
Coś pisze o tym, żeby dwa podpisy telefonów były na liście / spisie telefonów, wtedy niby ta funkcja będzie aktywna...
Czary mary :(
LYJO pisze:Nie za bardzo kumam o co loto w 2 i 3 zdaniu.
Czary mary :(
Minimum 2 telefony musza być na liscie urządzenia, inaczej funkcja będzie nieaktywna
Post autor: LYJO »
No właśnie, tylko problem z tym, że żaden telefon nie chce się połączyć z zestawem jak ten PIERWSZY jest już na liście. Obojętnie czy jest POŁĄCZONY czy nie :(
Nie wiem jak wygląda proces dodawania tel. ale wierze że robisz wszystko krok po kroku... Wg. tego co tu napisał jeżu
Musisz ustawić jeden z telefonów jako "standard - telefon1" a następny jako telefon 2. Jeżeli nie znajdzie drugiego aktywnego tel bo np. nie był aktywny bluetooth (jesteś pewien ze bluetooth jest właczony i tel ma aktywna funkcje "widziany dla innych urządzeń"?) to musisz dodac tel ręcznie poprzez liste tel lub włączenie i ponowne włączenie funkcji - "multipoint"
Post autor: LYJO »
LYJO pisze:Musisz ustawić jeden z telefonów jako "standard - telefon1" a następny jako telefon 2.
Niestety nie ma takiej możliwości.
Drugi telefon wykryje zestaw, ale nie może się w żaden sposób połączyć z nim.
Próbowałem już na 5 telefonach.
Pierwszy zawsze się połączy, Drugi nigdy... :(
A masz do niego instrukcje? maila Ci wysłałem
Ma to cudo jakąś liste tel w menu?
Post autor: LYJO »
Instrukcji brak. Liste telefonow ma ale tylko pokazuje zawsze ten pierwszy telefon,który sie sparuje.
Jeżeli połączenie Bluetooth® ma być ustanowione po raz pierwszy, należy uaktywnić funkcję
Bluetooth® w telefonie komórkowym i włączyć funkcję wyszukiwania urządzeń typu Bluetooth®. Trzeba odnaleźć urządzenie oznaczone symbolem „CC 9060...“. W razie wykrycia kilku urządzeń należy wybrać poszukiwane i wprowadzić nr PIN 1234. Telefon komórkowy połączy się wówczas (sparuje), wykorzystując połączenie Bluetooth®, z urządzeniem głośnomówiącym. W razie potrzeby należy wyszukać w telefonie funkcji „Połącz“ lub „Sparuj“, aby sparować urządzenie z telefonem.
Jeśli połączenie zostało nawiązane, na ekranie pojawi się nazwa telefonu i operatora, dane z książki telefonicznej (zapisane na karcie SIM) i adresowej (zapisane w pamięci telefonu) zostaną przesłane do urządzenia głośnomówiącego. Przesył może trwać kilka sekund w zależności od ilości danych, które są przesyłane. Jeśli w momencie przesyłu np. zadzwoni telefon, to może się zdarzyć, że nie wszystkie dane zostaną przesłane. W takim wypadku należy powtórzyć przesyłanie danych.
Ważna wskazówka:
Synchronizacja książki telefonicznej telefonu z urządzeXXniem głośnomówiącym odbywa się co pewien czas automatycznie. W tym czasie nie można korzystać z funkcji sterowania głosowego o czym poinformuje system.
W przypadku, gdy połączenie nie udało się, należy sprawdzić i aktualizować stan oprogramowania na telefonie lub zestawie głośnomówiącym. Szczegóły znajdują się na naszej stronie internetowej
www.bury.com.
Wskazówka:
Na naszej stronie internetowej znajduje się lista różnoXXrodnych modeli telefonów, które były testowane z tym modelem zestawu głośnomówiącego. Proszę mieć na uwadze, że użycie oprogramowania, którego nie ma na liście, może spowodować ograniczenie działania wszystkich dostępnych funkcji.
Może się zdarzyć, że muszą Państwo skasować w telefonie listę skonfigurowanych urządzeń, aby zestaw głośnomówiący skonfigurował prawidłowo połączenie. Proszę zapoznać się z instrukcją Państwa telefonu, jeśli mają Państwo pytania odnośnie menu, funkcji i obsługi, gdyż są one różne dla każdego telefonu.
Zestaw głośnomówiący może zapisać w pamięci konfigurację z 10 telefonami. W przypadku, gdy zechcą Państwo skonfigurować połączenie z 11 telefonem, proszę mieć na uwadze, że najstarszy zapis zostanie skasowany i zastąpiony nowym.
Połączenie Bluetooth® mogą Państwo przerwać w każdej chwili wyłączając tę funkcję w telefonie lub zestawie głośnomówiącym. Połączenie może zostać przerwane, jeśli oddalą się Państwo od samochodu i telefon straci zasięg z urządzeniem głośnomówiącym.
Należy pamiętać, że podczas włączonej funkcji Bluetooth® bateria telefonu szybko się wyczerpuje. Zalecamy wyłączenie funkcji Bluetooth® jeśli opuszczają Państwo samochód na dłuższy czas.
Post autor: LYJO »
Niestety dupa blada.
Poddaje się.
Nie da rady drugiego telefonu sparowac.
Próbowało już z 10 osób i nic.
Naszkryklołech to z mojego fona co mo Tapatalk i kery stoi w antryju na byfyju kole szklonki tyju ;)
