15-Airbags -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
Part No SW: 03G 906 016 BT HW: 028 101 176 1
Component: R4 1,9L EDC G210SG 5644
Revision: 12345678 Serial number: VWZ7Z0C8821390
Coding: 0000072
Shop #: WSC 00490 259 06516
VCID: 76E9F80101DC1C9
No fault code found.
Readiness: 0 0 1 1 1
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021190
Shop #: WSC 01324 785 00200
VCID: 3A712C317544B89
Part No: 1K0 907 044 K
Component: ClimatronicPQ35 063 0201
Shop #: WSC 00000 000 00000
VCID: 2F670D65BE066D1
Address 09: Cent. Elect. Labels: User\3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 L HW: 1K0 937 049 L*
Component: Bordnetz-SG 1.0 H30 0701
Revision: 00030000 Serial number: 00000000386320
Coding: 138B0F020004100000120C000000000000
VCID: 387536394B48AA9
Subsystem 1 - Part No: 1T0 955 119 B Labels: USER\1TX-955-119.LBL
Component: Wischer WWS A-MPV 0201
Coding: 16711828
Shop #: WSC 00000
Part No SW: 1T0 909 605 HW: 1T0 909 605
Component: 05 AIRBAG VW62 0506 2112
Coding: 0012341
VCID: F2E14411EDB4809
Address 16: Steering wheel Labels: User\1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000042
VCID: 30650E19A338729
Part No: 1T0 920 860 G
Component: KOMBIINSTRUMENT VDD 3350
Coding: 0007101
Shop #: WSC 00011 888 96745
VCID: 356B3F0D5C5A571
Part No: 1K0 815 071 F
Component: Zuheizer 030 1009
Revision: B Serial number: 09008374
Coding: 0000011
Shop #: WSC 00490 259 182489
VCID: 2855E6799BE83A9
5 Faults Found:
01412 - Glow-Plug with Flame Monitoring (Q8)
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 35
Reset counter: 32
Mileage: 216722 km
Time Indication: 0
Date: 2000.00.00
Time: 10:13:31
Start
Temperature: 76.0°C
Temperature: 71.0°C
000 - - - Intermittent
Fault Priority: 0
Fault Frequency: 35
Reset counter: 32
Mileage: 216722 km
Time Indication: 0
Date: 2000.00.00
Time: 10:13:31
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 36
Reset counter: 238
Mileage: 233256 km
Time Indication: 0
Date: 2000.00.00
Time: 16:50:12
01409 - Repeated Flame-Out
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 32
Mileage: 216652 km
Time Indication: 0
Date: 2000.00.00
Time: 15:54:34
Malfunction
Temperature: 72.0°C
Temperature: 66.0°C
02251 - Heater Unit Locked
Fault Priority: 0
Fault Frequency: 1
Reset counter: 32
Mileage: 216652 km
Time Indication: 0
Date: 2000.00.00
Time: 15:54:34
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 2100103C016A02
Coding: 7D3F1340078002
Shop #: WSC 00490 259 10064
VCID: 2757E54596F6351
Component: IMMO 3350
Shop #: WSC 44556 321 12345
Address 42: Door Elect, Driver Labels: User\1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0127
Coding: 0000116
VCID: F4ED420997A08E9
1 Fault Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
Address 44: Steering Assist Labels: User\1Kx-909-14x-44.lbl
Part No: 1K1 909 144 E
Component: EPS_ZFLS Kl.0 1202
VCID: 2D5B176DB40A1F1
Address 46: Central Conv. Labels: User\1K0-959-433-MIN.lbl
Part No: 1K0 959 433 C
Component: KSG 0545
Coding: 00E802087F2D8404084F0100
Shop #: WSC 77887 049 12345
Address 52: Door Elect, Pass. Labels: User\1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000116
VCID: F5EB7F0D9CDA971
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0001
Coding: 0000001
Part No: 1K0 035 186 G
Component: Radio BNO 0013
Coding: 0040400
VCID: 2A511C7185E4089
2 Faults Found:
000 - -
00003 - Control Module
014 - Defective
Address 62: Door, Rear Left Labels: User\1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0201
Coding: 0000048
Address 72: Door, Rear Right Labels: User\1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000048
Z tego co już zdążyłem się dowiedzieć to dogrzewacz jest zablokowany? Nie grzeje lewe lusterko.. Jaki może być powód braku klaksonu ?
Dzięki za wskazówki
MArcelid - wielkie ukłony za pomoc
