kilka błędów prośba o wyjasnienie
marek83
Auto:: Touran 1.9 tdi BLS
Post autor: marek83 »
czy jest ktoś tak miły i pomoże przetłumaczyc co jest w tych błędach
dziś przyszedł kabelek pierwszy skan ;)
Pozdr
Friday,29,November,2013,16:35:49:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56
VIN: WVGZZZ1TZ8W058337 Mileage: 174430km/108385miles
15-Airbags -- Status: OK 0000
56-Radio -- Status: OK 0000
Part No SW: 03G 906 021 RN HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 1989
Revision: --H07--- Serial number: VWX7Z0G83N60C4
Coding: 0000072
Shop #: WSC 08487 264 96054
VCID: 7CFDEA293FF0469
1 Fault Found:
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit
Fault Status: 01110000
Fault Priority: 3
Fault Frequency: 17
Mileage: 146408 km
Time Indication: 0
Date: 2000.00.00
Time: 19:26:41
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00101100
Temperature: 22.5įC
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Revision: 00H11001
Coding: 0021190
Shop #: WSC 01324 785 00200
VCID: 73EFC11512AE091
No fault code found.
Part No SW: 1K0 907 044 BR HW: 1K0 907 044 BR
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 78F5F6390BC86A9
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: User\3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007537049
Coding: 01890F2100040F0047120C000000000000087F075C000100000000000000
VCID: 71E3CB1D68B23B1
Subsystem 1 - Part No: 2K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 270807 021 0501
Coding: 00038805
Shop #: WSC 01324
Revision: 02021000 Serial number: 003B9D05SUS+
Coding: 0012340
VCID: 36693801415C5C9
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksšulenmodul 636 0070
Coding: 0000042
VCID: 74EDC20917A00E9
1 Fault Found:
00883 - Ignition Switch (D) Terminal S
Address 17: Instruments Labels: User\1K0-920-xxx-17.lbl
Part No SW: 1T0 920 864 A HW: 1T0 920 864 A
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0G83N60C4
Coding: 0003101
Shop #: WSC 80093 222 69422
VCID: 336F0115522E491
Part No: 1K0 815 071 T
Component: Zuheizer 050 2504
Coding: 0000011
3 Faults Found:
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 2
Reset counter: 132
Mileage: 162872 km
Time Indication: 0
01412 - Glow-Plug with Flame Monitoring (Q8)
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 6
Reset counter: 100
Mileage: 149422 km
Time Indication: 0
Start
Temperature: 84.0įC
Temperature: 83.0įC
Voltage: 14.09 V
02251 - Heater Unit Locked
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 100
Mileage: 165333 km
Time Indication: 0
Revision: H07 01 Serial number: 010907F1000461
Coding: E9801F06000A028002
VCID: 30650E19A338729
Component: IMMO VDD 1212
Component: Tuer-SG 006 1201
Coding: 0000053
VCID: 387536394B48AA9
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.071 H08 1901
VCID: 356B3F0D5C5A571
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 80C802087F2D8405484B036010CC
VCID: 80051ED9D318A29
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Coding: 0000052
VCID: 3973333D7042B31
2 Faults Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Part No SW: 1K0 035 186 AD HW: 1K0 035 186 AD
Component: Radio BVX 035 0047
Revision: 00035000 Serial number: VWZ1Z2G6248016
Coding: 0020200
VCID: 68D5A6795B68FA9
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 18: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 42: DTCs cleared
Address 44: DTCs cleared
Address 46: DTCs cleared
Address 52: DTCs cleared
Address 56: DTCs cleared
Chassis Type: 1K0
Coding: 0000072
Readiness: 0 0 0 0 1
Revision: 00H11001
Coding: 0021190
Coding: 00038805
Shop #: WSC 01324
Coding: 0012340
Coding: 0000042
Coding: 0003101
Coding: 0000011
3 Faults Found:
00664 - Fuel gauge
Fault Priority: 6
Fault Frequency: 2
Reset counter: 132
Mileage: 162872 km
Time Indication: 0
Fault Priority: 3
Fault Frequency: 6
Reset counter: 100
Mileage: 149422 km
Time Indication: 0
Start
Temperature: 84.0įC
Temperature: 83.0įC
Voltage: 14.09 V
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 100
Mileage: 165333 km
Time Indication: 0
Coding: 0000053
Component: KSG 0401
Coding: 0000052
Coding: 0020200
kervan01
Auto:: Touran 1.9 TDI BKC 2005r
Imię:: Radek
Otrzymał podziękowań: 10 razy
Re: kilka błędów prośba o wyjasnienie
Post autor: kervan01 »
W Silniku
005660 - Glowplug for Cylinder 3 (Q12) - przepalona świeca żarowa na cylindrze 3, do wymiany
Webasto Zablokowane,
przeczytaj ten temat
http://touranklub.pl/forum/viewtopic.php?t=3721
http://touranklub.pl/forum/viewtopic.php?t=28
Aby odblokować w Adaptacji w kanale 42 wpisz 1
następnie wykasuj błędy i zrób test
admin
Imię:: Maciek
Post autor: admin »
Mało czynnika w klimie, błąd na pewno wróci.
marek83
tak, cos z tym webastem nie gra w zeszła zimę dymiło codziennie w tym roku tylko raz zadymiło i koniec. Nie wiem czy ono działa bo nie widze zeby sie szybko rozgrzewał silnik a wręcz przeciwnie 90 stopni teraz łapie po przejechaniu 15-20km może nie działac
-- 29 lis 2013, o 22:14 --
klima nie działała w lato jeszcze a w październiku juz nie, a w tym roku nabijałem
-- 29 lis 2013, o 22:16 --
ale napisalem ... klima w lato działała bo na wiosne nabijałem a na jesieni juz nie działała
kervan01
Imię:: Radek
w Webato masz błąd świec żarowych. Więc mogą być one uszkodzone i do wymiany.
Odblokuj webasto i zobacz co się dzieje.
O części do webasto jak co pytaj jarrego, on jest twórcą manuali od webasto
W drzwiach pasażera masz błąd jednego silniczka.
Najprawdopodobniej zamek do wymiany. Możesz też posprawdzać zimne luty.
marek83
ok sprawdze, w ogole to mam objawy dwumasu chyba, delikatnie trzesie autem na luznym biegu z lewego nadkola slychac czasami dziwny dzwiek a przy przyspieszaniu na 1 2 3 biegu tylko jak mocniej wcisne tak od 2000obr tez słychac dziwny metaliczny dzwięk, czy to sprzegło czy skrzynia? a moze przegub ?bo cos pyka w lewym kole od kierowcy jak cofam.... kurde auto mi sie sypie :\
-- 29 lis 2013, o 22:29 --
ten zamek juz dawno mi wywalało pilot cos z bliska tylko działa najlepiej od kierowcy przy lusterku baterie w pilocie ok
Klima może mieć wyciek czynnika dlatego tak szybko padła. Piec może być do czyszczenia ale wypada najpierw spróbować odblokować. Sprawdź działanie świecy (palnika) w piecu zgodnie z manualem Jarry-ego, świeca na 3 cylindrze do wymiany. Raczej masz dwumas do roboty ale nie ma co jeszcze panikować. Lekkie drgania to jeszcze nie jest tragedia.
marek83
a wiec z logu wynika ze mam? :
1 świeca żarowa 3 cylinder
2 świeca od webasto
3 zamek w drzwiach pasazera
4 klima
to wszystko czy jeszcze cos można wywnioskowac z logu?
00664 fuel gauge o czym mowi ten błąd?
pabloxxx
Auto:: Touran 1,9 TDI
Post autor: pabloxxx »
marek83 pisze:00664 fuel gauge o czym mowi ten błąd?
Tym błędem się nie przejmuj , związany jest on z rezerwą paliwa, dogrzewacz nie działa przy niskim stanie ropy.
marek83
wymieniłem dzis świece w 3 cylindrze, odblokowałem webasto lecz nie wiem czy działa zaraz przejade sie zobacze czy dymi.
Zrobiłem scan:
Monday,02,December,2013,17:10:35:32264
Chassis Type: 1K0
VIN: WVGZZZ1TZ8W058337 Mileage: 174600km/108491miles
Coding: 0000072
2 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Mileage: 174458 km
Time Indication: 0
Date: 2000.00.00
Time: 13:59:35
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00101100
Temperature: 5.4°C
Bin. Bits: 00110000
005522 - Altitude Sensor / Boost Pressure Sensor
P1592 - 000 - Implausible Correlation - MIL ON
Fault Status: 11100000
Fault Priority: 1
Fault Frequency: 4
Time Indication: 0
RPM: 0 /min
Speed: 0.0 km/h
Pressure: 48 mbar
Pressure: -256 mbar
Bin. Bits: 00011010
Absolute Pres.: 999.6 mbar
Absolute Pres.: 856.8 mbar
Readiness: 1 1 0 0 0
Revision: 00H11001
Coding: 0021190
Coding: 00038805
Shop #: WSC 01324
Coding: 0012340
Component: Lenksäulenmodul 636 0070
Coding: 0000042
1 Fault Found:
Coding: 0003101
Coding: 0000011
3 Faults Found:
00664 - Fuel gauge
Fault Priority: 6
Fault Frequency: 2
Reset counter: 132
Mileage: 162872 km
Time Indication: 0
Fault Priority: 3
Fault Frequency: 6
Reset counter: 100
Mileage: 149422 km
Time Indication: 0
Start
Temperature: 84.0°C
Temperature: 83.0°C
Voltage: 14.09 V
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 100
Mileage: 165333 km
Time Indication: 0
Coding: 0000053
Component: KSG 0401
Coding: 0000052
2 Faults Found:
Coding: 0020200
nastepnie wyczysciłem błedy zrobiłem scan i wyszło tak:
Monday,02,December,2013,17:36:00:32264
Chassis Type: 1K0
Coding: 0000072
Revision: 00H11001
Coding: 0021190
Coding: 00038805
Shop #: WSC 01324
Coding: 0012340
Coding: 0000042
Coding: 0003101
Coding: 0000011
Coding: 0000053
Component: KSG 0401
Coding: 0000052
Coding: 0020200
Czy juz w miare to wygląda ok ?
marek83 pisze:Czy juz w miare to wygląda ok ?
Skoro błędów nie ma jest :oki:
marek83
Czułem że Webasto sie załączy i się załączyło najpierw zaczęło śmierdzieć z nawiewów olejem i po chwili zaczęło trochę dymić ale na krótką chwilę ale nie z taką intensywnością jak w zeszłą zimę.
Tak czy siak chyba działa tylko dlaczego kopci się z niego?
kervan01
Imię:: Radek
Pojeździj kilka dni i zrób ponownie skan. Zobaczysz czy jakieś błędy wrócą.
Co do Webasto to jeżeli dymienie to po pierwszym odpaleniu po dłuższym czasie to normalne.
Jeżeli będzie się powtarzało to tak jak pisał niko02 najprawdopodobniej piec jest do czyszczenia.
marek83
ok następny skan po przejechaniu około 100 km
Coding: 0000011
2 Faults Found:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 6
Reset counter: 97
Mileage: 174613 km
Time Indication: 0
Start
Temperature: 72.0°C
Temperature: 71.0°C
Voltage: 14.24 V
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 174688 km
Time Indication: 0
Czyli znowu to webasto co z nim zrobić ?
również powtarza się i ten błąd
Coding: 0000072
1 Fault Found:
P1592 - 000 - Implausible Correlation - Intermittent
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Time Indication: 0
RPM: 0 /min
Speed: 0.0 km/h
Pressure: 46 mbar
Pressure: -256 mbar
Bin. Bits: 00011010
Absolute Pres.: 1009.8 mbar
oraz taki
Coding: 0000042
1 Fault Found:
nie wiem również za bardzo o co chodzi w tych grupach
Address 01: Engine (03G 906 021 RN)
15:33:56 Group 041
95.5 % Duty Cycle
0.0 % Duty Cycle
0.0 % Duty Cycle
0.0 % Duty Cycle
Tuesday,03,December,2013,15:35:04:32264
15:34:57 Group 046
95.5 % Duty Cycle
4.8 % Duty Cycle
4.7 % Duty Cycle
10.3 % Duty Cycle
oraz zrobiłem test wtrysków i w grupie 23 wykraczam juz dość mocno poza skale 30 nawet do 40 podbija.
15:31:42 Group 013
-0.02 mg/str Inj. Quantity
-0.19 mg/str Inj. Quantity
0.07 mg/str Inj. Quantity
0.14 mg/str Inj. Quantity
15:31:42 Group 018
0.0 (no units)
0.0 (no units)
0.0 (no units)
0.0 (no units)
15:31:42 Group 023
-30.0 (no units)
-28.0 (no units)
-12.0 (no units)
-34.0 (no units)
Tuesday,03,December,2013,15:34:07:32264
Z góry dzięki jak ktoś pomoże :piwo:
JacaTouran
Auto:: Touran 1.9tdi Bxe
Podziękował: 213 razy
Post autor: JacaTouran »
Webasto rozebrać, wyczyścić sito, założyć zestaw naprawczy i będzie działać. Ten 3 cylinder to przypadkiem nie wtryskiwacz ;-) ? Czujnik ciśnienia atmosferycznego do wymiany. Auto przypadkiem nie jest mulowate? Nie poszarpuje?
