kubawojcik pisze:Czy znajdzie sie posidacz 1t3 z lusterkami full (skladane elektrycznie i z doswietlaniem) ktory moglby wrzucic tutaj autoscan z vcds?
Dzieki
Autoskan kolegi
Chassis Type: 7N0
Scan: 01 03 08 09 10 15 16 17 18 19 25 37 42 44 46 52 55 56 61 62
69 72
VIN: WVGZZZ1TZCW........
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.lbl
Part No SW: 03L 906 023 PH HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 0874
Revision: --H43--- Serial number: 00000000000000
Coding: 00194036032401080000
Shop #: WSC 01324 020 00200
ASAM Dataset: EV_ECM16TDI02103L906023PH 003003
ROD: N/A
VCID: 7BF1F3DF4125
No ASAM data for: "EV_ECM16TDI02103L906023PH" (VW36)
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: User1K0-907-379-60EC1F.lbl
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 323B401609290EFC4C1202E5901E7051310150
VCID: 7BF1F3DF4125
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.lbl
Part No SW: 5K0 907 044 FA HW: 5K0 907 044 FA
Component: Climatronic H18 1113
Revision: 00001004
Coding: 0000004003
ASAM Dataset: EV_Climatronic A01010
ROD: EV_Climatronic_VW36.rod
VCID: 6FE9D78F055D
Address 09: Cent. Elect. (J519) Labels: User1K0-937-08x-09.lbl
Part No SW: 5K0 937 087 R HW: 5K0 937 087 R
Component: BCM PQ35 H 021 0064
Revision: BE021001
Coding: 40180A3888251AE0400800C0540011E44B559008626DA520E480C7000049
VCID: 448348237C5B
Subsystem 1 - Part No: 1T1 955 119 A
Component: Wischer 02121 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH
Component: RLS 071211 05 54 0403
Coding: 0230ED
Address 10: Park/Steer Assist (J791) Labels: 3AA-919-475.lbl
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261134001063
Coding: 158201
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000_VW36.rod
VCID: 448348237C5B
Part No SW: 1T0 909 605 E HW: 1T0 909 605 E
Component: 02 AIRBAG VW8 022 0100
Revision: 02022000 Serial number: 003K4D056DV9
Coding: 0012338
VCID: 37792FEF3D8D
Address 16: Steering wheel (J527) Labels: 5K0-953-569.lbl
Part No SW: 5K0 953 501 BH HW: 5K0 953 569 L
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20111209302008
Coding: 118A140000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS_VW36.rod
VCID: 71EDD1F71369
MFL:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Coding: 820000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.lbl
Part No SW: 1T0 920 885 A HW: 1T0 920 885 A
Component: KOMBI H04 0407
Coding: 181F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 366722EB3A87
Address 18: Aux. Heat Labels: 1K0-815-007.lbl
Part No: 7N0 963 272 A
Component: Standheizer 043 4730
Revision: 00043000 Serial number: 09022127000000
Coding: 0031032
Shop #: WSC 32674 000 1048576
VCID: 33611BFF29F5
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.lbl
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 051211F2001715
Coding: 358002
VCID: 3B7133DF01A5
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.lbl
Component: IMMO H04 0407
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EADF469BBEBF
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.lbl
Part No SW: 3C0 035 279 H HW: 3C0 035 279 H
Component: RNS315-EU H35 0263
Serial number: VWZAZ2L3......
Coding: 000004110400090000021301
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: N/A
VCID: 285BFC93E033
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_0038 0038
No ASAM data for: "EV_RNS315EUV2UDS" (VW36)
1 Fault Found:
1048642 - ROD - Unknown Error Code
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Mileage: 117430 km
Date: 2030.14.00
Time: 11:31:11
Address 42: Door Elect, Driver Labels: User1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2121
Coding: 0135351
VCID: 76E7E2EB7A07
Address 44: Steering Assist Labels: 5N1-909-144.lbl
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.293 1002
Revision: 1AH03734 Serial number: 00113370022701
Coding: 0000258
VCID: 3C7330C304AB
Address 52: Door Elect, Pass. Labels: User1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0135607
VCID: 489B5C134073
Address 55: Xenon Range (J745) Labels: 5M0-907-357-V3.lbl
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: --------------
Coding: 038200000B000200
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt.rod
VCID: 37792FEF3D8D
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.lbl
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1623
Coding: 030F185A
VCID: F1ED51F79369
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Address 62: Door, Rear Left Labels: User1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2104
Coding: 0131216
Shop #: WSC 01324 020 1012552
VCID: 326F1EFBD6EF
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00000162698203
Coding: 410D000100000000
VCID: 306B14F3D8E3
Address 72: Door, Rear Right Labels: User1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0131216
VCID: 33611BFF29F5
