yox pisze:... pokaż autoscan i odlącz na chwile aku
To już jutro zrobię i wyślę
Po odpięciu akumulatora problem nadal jest
Oto co pokazał scan:
Sunday,28,July,2019,18:38:40:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WVGZZZ1TZ9W076556   License Plate:
Mileage: 265280km-164837mi   Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 42 44 46 52 56 62 72 77
VIN: WVGZZZ1TZ9W076556   Mileage: 265280km-164837miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
15-Airbags -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 ND    HW: 03G 906 021 AB
   Component: R4 1,9L EDC G000AG  3078
   Revision: --H09---    Serial number: VWX7Z0HN3NC0S7
   Coding: 0000077
   Shop #: WSC 01324 020 00200
   VCID: 6ED378B97997023A37-803A
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 048 G    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 1802
   Revision: 00043014    Serial number: 00001304165192
   Coding: 0000020
   Shop #: WSC 04940 001 00001
   VCID: 3467AAD1573B68EA01-8060
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H14001
   Coding: 0053958
   VCID: 68DF0EA15B73DC0A7D-803C
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 DA    HW: 1K0 907 044 DA
   Component: ClimatronicPQ35 133 1213
   Revision: 00133024    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 69D90BA54079E50262-803C
1 Fault Found:
01592 - Air Quality Sensor (G238)
            014 - Defective - Intermittent
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
   Component: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serial number: 00000009127545
   Coding: 118B8F2100040F0047120C000000000000087F075C00012C000000000000
   VCID: 3365A9CD52356FD218-8066
   Subsystem 1 - Part No: 2K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 291008 021  0501
   Coding: 00038805
   Shop #: WSC 01324
1 Fault Found:
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 235
                    Mileage: 264852 km
                    Time Indication: 0
                        ON
                    Voltage: 13.60 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 F    HW: 1K0 919 475 F
   Component: PARKHILFE     005 1506
   Revision: 00005000    Serial number: 0 263 004 300
   Coding: 100101
   VCID: 356197D59C4171E236-8060
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 D    HW: 1T0 909 605 D
   Component: 04 AIRBAG VW8   021 0100
   Revision: 02021000    Serial number: 003B9D0B8B9W
   Coding: 0012340
   VCID: 366390D941477AFA3F-8062
   Subsystem 1 - Serial number: 6332QSME7F0D1216K
   Subsystem 2 - Serial number: 6342QSME09004A0CB
   Subsystem 3 - Serial number: 6352QSME7709521EM
   Subsystem 4 - Serial number: 6362QSME49092B3AQ
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           855 0111
   Coding: 0001132
   VCID: 76E350D901C73AFAFF-8022
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0010
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1T0 920 874 A    HW: 1T0 920 874 A
   Component: KOMBIINSTRUMENT VDD 2416
   Revision: V0005000    Serial number: VWX7Z0HN3NC0S7
   Coding: 0007101
   Shop #: WSC 80093 222 71269
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 1K0 815 071 T
   Component: Zuheizer        050 2504
   Revision: 00050000    Serial number: 09009839000000
   Coding: 0000011
   Shop #: WSC 00727 727 65355
5 Faults Found:
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 41
                    Reset counter: 152
                    Mileage: 221288 km
                    Time Indication: 0
                        Locked
                    Temperature: 89.0°C
                    Temperature: 88.0°C
                    Voltage: 13.59 V
01412 - Glow-Plug with Flame Monitoring (Q8)
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 6
                    Reset counter: 152
                    Mileage: 222260 km
                    Time Indication: 0
                        Start
                    Temperature: 48.0°C
                    Temperature: 50.0°C
                    Voltage: 14.45 V
00664 - Fuel gauge
                    Fault Status: 00100010
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: 222379 km
                    Time Indication: 0
            000 -  -  - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 151
                    Mileage: 222379 km
                    Time Indication: 0
02251 - Heater Unit Locked
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 112
                    Mileage: 222419 km
                    Time Indication: 0
Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533  Gateway   H07 0071
   Revision:   H07 01    Serial number: 111108F2001678
   Coding: EDA07F06000E02008002
   VCID: 377D9DDD464D83F224-8062
2 Faults Found:
01303 - Telephone Transceiver (R36)
                    Fault Status: 00110100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 16
                    Mileage: 265238 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:41:16
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 265238 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:22:35
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 2416
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 M    HW: 1T0 959 701 M
   Component: Tuer-SG         008 2007
   Coding: 0000181
   VCID: 4189F3051889CD429A-8014
1 Fault Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 01324 785 00200
   VCID: 2A5BB4A985FF2E1AAB-807E
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 8090020851030C7F2D06840560084F03E0FC00
   VCID: 0305390D42151F52C8-8056
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1T0 959 702 M    HW: 1T0 959 702 M
   Coding: 0000181
   VCID: 428BFC091D8FD65A83-8016
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: RCD510        H16 5026
   Revision: -----13S    Serial number: VWZ4Z3L1116719
   Coding: 0100040004
   VCID: 65C107956C61C16246-8030
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 AK    HW: 1K0 959 703 AK
   Component: Tuer-SG         007 2002
   Coding: 0000144
   Shop #: WSC 01324 020 1012552
   VCID: 79F95BE530D9558292-802C
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 AK    HW: 1K0 959 704 AK
   Coding: 0000144
   VCID: 7AFB44E935DF5E9A9B-802E
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 5P0 862 335 D    HW: 5P0 862 335 D
   Component: FSE_2P7x        H36 0120
   Revision: 00000001    Serial number: 00000005022961
   Coding: 0000492
   Shop #: WSC 06402 785 00200
End-------------------------(Elapsed Time: 02:05)--------------------------
