Błędy z Autoscanu
- Tomas
- Podziękował: 438 razy
robiłem scan dzis , wyszły mi błędy które się powtarzają, na swoje potrzeby przetłumaczyłem je sobie ale jakby ktoś mądrzejszy na to rzucił okiem, będę wdzięczny:
Thursday,26,April,2012,18:15:40:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ4W152738 Mileage: 229190km/142412miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
Part No SW: 03G 906 016 BT HW: 028 101 176 1
Component: R4 1,9L EDC G010SG 7210
Revision: 12345678 Serial number: VWZ7Z0D9517412
Coding: 0000072
Shop #: WSC 00330 259 09948
VCID: 76E7E2EB7A07
No fault code found.
Readiness: 0 0 0 0 0
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021190
Shop #: WSC 01324 785 00200
VCID: 3A7F36DB0E9F
Part No: 1K0 907 044 K
Component: ClimatronicPQ35 061 0201
Shop #: WSC 00000 000 00000
VCID: 2F69178FC5DD
Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000000650392
Coding: 01890F020004200000120C000000000000
VCID: 408B44336843
Subsystem 1 - Part No: 1T0 955 119 C
Coding: 00065493
Shop #: WSC 00000
1 Fault Found:
Component: 05 AIRBAG VW62 0506 2112
Coding: 0012341
VCID: F2EF5EFB966F
Component: Lenksäulenmodul 012 0030
Coding: 0000042
VCID: 306B14F3D8E3
Part No: 1T0 920 860 G
Component: KOMBIINSTRUMENT VDD 3354
Coding: 0003101
Shop #: WSC 00266 266 08014
VCID: 356525E72781
Part No: 1K0 815 071 P
Component: Zuheizer 031 1312
Coding: 0000112
VCID: 326F1EFBD6EF
5 Faults Found:
02456 - Line Filling
005 - No or Incorrect Basic Setting / Adaptation
02251 - Heater Unit Locked
000 - - - Intermittent
00664 - Fuel gauge
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 26
Reset counter: 35
Mileage: 227441 km
Time Indication: 0
Date: 2000.00.00
Time: 25:45:00
02085 - Incorrect Control Module Installed
Fault Priority: 0
Fault Frequency: 26
Reset counter: 35
Mileage: 227441 km
Time Indication: 0
Date: 2000.00.00
Time: 25:45:00
01408 - Under-Voltage Shut-Off (fixed Value)
Fault Status: 00100000
Fault Priority: 0
Reset counter: 108
Mileage: 228780 km
Time Indication: 0
Date: 2000.00.00
Time: 23:39:19
Malfunction
Temperature: 40.0°C
Temperature: 49.0°C
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 26001043050342
Coding: 3D3F1340078002
VCID: 2759FFAFED2D
Component: IMMO 3354
VCID: 356525E72781
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0127
Coding: 0000116
VCID: F4E358E3EC7B
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.0 1302
VCID: 2E570A8BC2D7
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 00E802087F2D8404084F0100
VCID: 306B14F3D8E3
Part No: 1T0 959 702
Coding: 0000116
VCID: F5E565E7E701
Part No: 1K0 035 186 J
Component: Radio GR0 0014
Revision: 0001002S Serial number: VWZ2Z2D1243903
Coding: 0040400
VCID: 2D550D87CFD1
2 Faults Found:
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
00879 - Connection to Speaker Front Right
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0201
Coding: 0000048
VCID: 2F69178FC5DD
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 306B14F3D8E3
Chassis Type: 1K0
Coding: 0000072
VCID: 76E7E2EB7A07
Coding: 0021190
VCID: 3A7F36DB0E9F
VCID: 2F69178FC5DD
VCID: 408B44336843
Coding: 00065493
Shop #: WSC 00000
1 Fault Found:
Coding: 0012341
VCID: F2EF5EFB966F
Coding: 0000042
VCID: 306B14F3D8E3
Coding: 0003101
VCID: 356525E72781
Coding: 0000112
VCID: 326F1EFBD6EF
5 Faults Found:
00664 - Fuel gauge
Fault Priority: 0
Fault Frequency: 26
Reset counter: 35
Mileage: 227441 km
Time Indication: 0
Date: 2000.00.00
Time: 25:45:00
Fault Priority: 0
Fault Frequency: 26
Reset counter: 35
Mileage: 227441 km
Time Indication: 0
Date: 2000.00.00
Time: 25:45:00
Fault Priority: 0
Reset counter: 108
Mileage: 228780 km
Time Indication: 0
Date: 2000.00.00
Time: 23:39:19
Malfunction
Temperature: 40.0°C
Temperature: 49.0°C
VCID: 2759FFAFED2D
VCID: 356525E72781
Coding: 0000116
VCID: F4E358E3EC7B
VCID: 2E570A8BC2D7
Component: KSG 0201
VCID: 306B14F3D8E3
Coding: 0000116
VCID: F5E565E7E701
Coding: 0040400
VCID: 2D550D87CFD1
2 Faults Found:
011 - Open Circuit
Coding: 0000048
VCID: 2F69178FC5DD
Coding: 0000048
VCID: 306B14F3D8E3
- jarry
- Imię:: Rołbert
- Podziękował: 584 razy
- Otrzymał podziękowań: 828 razy
02251 - piec zablokowany, jak odblokować przeczytasz w moim manualu
00664 - rezerwa paliwa - sporadycznie
02085 - problem w komunikacji z piecem - sporadyczny
01408 - zbyt niskie napięcie do odpalenia pica - sporadycznie
02456 - Line Filling ????
01064 - na początek sprawdź żaróweczkę w gnieździe zapalniczki,
00875 - przerwa w obwodzie syczka prawy przód
00879 - wyciągałeś lub masz luźne styki w głośniczku przednim prawym
- Auto:: 1T1
- Imię:: -
- Podziękował: 32 razy
To i ja zapodam swoj autoscan, ,czyzby kilka bledow bylo spowodowane niskim napieciem?
Mileage: 170010km/105639miles
03-ABS Brakes -- Status: Sporadic communication error 1000
56-Radio -- Status: OK 0000
Part No SW: 03G 906 016 CD HW: 028 101 194 5
Component: R4 1,9L EDC G000SG 6246
Revision: 12345678 Serial number: VWZ7Z0D1087861
Coding: 0000072
VCID: 67D9BFAF2DAD
Coding: 0021190
VCID: 3A7F36DB0E9F
Part No: 1K0 907 044 AB
Component: ClimatronicPQ35 066 0404
VCID: 67D9BFAF2DAD
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001257329
Coding: 00890F020004100000120C000000000000087B075C
VCID: 397D29D70B99
Subsystem 1 - Part No: 2K1 955 119 B
Component: Wischer VW357 012 0402
Coding: 00065493
Shop #: WSC 00000
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0AFBSD
Coding: 0012338
VCID: 356525E72781
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 021 0050
Coding: 0000042
VCID: 356525E72781
Part No: 1T0 920 861 A
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0003103
Shop #: WSC 00707 211 97245
VCID: 306B14F3D8E3
1 Fault Found:
01316 - ABS Control Module
Part No: 1K0 815 071 H
Coding: 0000011
VCID: 2A5F069BFE3F
3 Faults Found:
01411 - Temperature Sensor (G18)
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 3
Reset counter: 43
Mileage: 168740 km
Time Indication: 0
Date: 2000.00.00
Time: 21:18:30
Ctrl. Pause
Temperature: 205.0°C
Temperature: 78.0°C
Fault Priority: 0
Fault Frequency: 3
Reset counter: 43
Mileage: 168740 km
Time Indication: 0
Date: 2000.00.00
Time: 21:18:30
01409 - Repeated Flame-Out
Fault Priority: 0
Fault Frequency: 1
Reset counter: 43
Mileage: 168728 km
Time Indication: 0
Date: 2000.00.00
Time: 20:01:53
Malfunction
Temperature: 69.0°C
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104B120923
Coding: 3D0F1340078002
VCID: 295DF997FB39
1 Fault Found:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 83
Mileage: 169804 km
Time Indication: 0
Date: 2000.00.00
Time: 10:25:48
Component: IMMO VDD 0814
VCID: 306B14F3D8E3
Component: Tuersteuergeraet 09 0157
Coding: 0000052
VCID: F4E358E3EC7B
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.6 1401
VCID: 2F69178FC5DD
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 80E802087F2D8404084B016010
VCID: 7BF1F3DF4125
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Part No: 1K0 035 186 L
Component: Radio GR0 012 0018
Revision: 0001201S Serial number: VWZ2Z2D1594919
Coding: 0040400
VCID: 2F69178FC5DD
Coding: 0000072
VCID: 67D9BFAF2DAD
Coding: 0021190
VCID: 3A7F36DB0E9F
VCID: 67D9BFAF2DAD
VCID: 397D29D70B99
Coding: 00065493
Shop #: WSC 00000
Coding: 0012338
VCID: 356525E72781
Coding: 0000042
VCID: 356525E72781
Coding: 0003103
VCID: 306B14F3D8E3
1 Fault Found:
Coding: 0000011
VCID: 2A5F069BFE3F
3 Faults Found:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 43
Mileage: 168740 km
Time Indication: 0
Date: 2000.00.00
Time: 21:18:30
Ctrl. Pause
Temperature: 78.0°C
Fault Priority: 0
Fault Frequency: 3
Reset counter: 43
Mileage: 168740 km
Time Indication: 0
Date: 2000.00.00
Time: 21:18:30
Fault Priority: 0
Fault Frequency: 1
Reset counter: 43
Mileage: 168728 km
Time Indication: 0
Date: 2000.00.00
Time: 20:01:53
Malfunction
Temperature: 69.0°C
VCID: 295DF997FB39
1 Fault Found:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 83
Mileage: 169804 km
Time Indication: 0
Date: 2000.00.00
Time: 10:25:48
VCID: 306B14F3D8E3
Coding: 0000052
VCID: F4E358E3EC7B
VCID: 2F69178FC5DD
VCID: 7BF1F3DF4125
Coding: 0040400
VCID: 2F69178FC5DD
				pawel07777
- Auto:: Touran 2.0 2011
- Imię:: Paweł
- Podziękował: 5 razy
Wszystkie błędy są sporadyczne skasuj błędy i po pewnym czasie sprawdź czy nie powracają.
Trzy błędy miałeś na webaście spróbuj odpalić webasto jak tego dokonać zajrzyj tutaj .
WITAM [you]
				fajowiec
- Auto:: Highline 1.6fsi 03
- Imię:: Pioter
Znaczenie błędów-czy ktoś wie..?
Witam forumowiczów, czy ktoś jest w stanie mi pomóc w rozszyfrowaniu tych błędów:
17977 - Cruise Control Switch (E45): Implausible Signal
P1569 - 008 - Implausible Signal
17441 - Sensor for NOx (G295): Signal too Low
P1033 - 002 - Lower Limit Exceeded - MIL ON
17443 - Sensor for NOx (G295): Signal Implausible
P1035 - 002 - Lower Limit Exceeded
z góry dziekuję
z góry dziekuję
- r00x
- Auto:: Audi A4 2.0 TFSI Quattro
- Imię:: Sebastian
W związku z tym iż przymierzam się do wymiany gatway'a zakupiłem kabel i zrobiłem sobie autoscana. Jako że dopiero rozpoczynam przygodę z vcds proszę o pomoc w rozkodowaniu błędów. Jeżeli chodzi o radio to wiem co z nim nie tak. Reszta jak na razie jest dla mnie zagadką  Z góry dziękuję za okazaną pomoc
  Z góry dziękuję za okazaną pomocKod: Zaznacz cały
Wednesday,25,July,2012,17:52:52:32264
VCDS Version: Release 11.11.0
Data version: 20111111
Chassis Type: 1K0
VIN: WVGZZZ1TZ4W132033   Mileage: 212270km/131898miles
01-Engine -- Status: Sporadic communication error 1000
   Component: R4 1,9L EDC G000SG  5644
   Revision: 12345678    Serial number: VWZ7Z0D9295950
   Coding: 0000072
   VCID: 76E9F80101DC22E
   Coding: 0021190
   VCID: 3A712C31754486E
2 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
            003 - Mechanical Failure - Intermittent
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
   VCID: 2F670D65BE06536
   Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
   Component: Bordnetz-SG 1.0 H30 0701
   Revision: 00030000    Serial number: 00000000510845
   VCID: 3777350546569B6
   Subsystem 1 - Part No: 1T0 955 119 B  Labels: 1TX-955-119.CLB
   Component: Wischer WWS A-MPV   0201
   Coding: 16711828
   Shop #: WSC 00000
3 Faults Found:
02395 - Parking Light Right Front (M3)
01314 - Engine Control Module
   Coding: 0012341
   VCID: F2E14411EDB4BEE
   Coding: 0000042
   VCID: 30650E19A3384CE
   Coding: 0003101
   Shop #: WSC 00581 210 64475
   VCID: 356B3F0D5C5A696
1 Fault Found:
   Part No: 1K0 815 071 F
   Component: Zuheizer        030 1009
   Revision:        B    Serial number: 09008374
   Coding: 0000011
   VCID: 2855E6799BE804E
5 Faults Found:
00664 - Fuel gauge
                    Fault Priority: 0
                    Fault Frequency: 157
                    Reset counter: 24
                    Mileage: 205651 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:38:26
00003 - Control Module
            014 - Defective - Intermittent
                    Fault Priority: 0
                    Reset counter: 24
                    Mileage: 205651 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:38:26
                    Fault Status: 00101010
                    Fault Priority: 0
                    Reset counter: 236
                    Mileage: 212275 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:29:39
                        OFF
                    Temperature: 83.0°C
                    Temperature: 83.0°C
                    Fault Priority: 0
                    Reset counter: 236
                    Mileage: 212275 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:29:39
                    Fault Priority: 0
                    Reset counter: 236
                    Mileage: 212275 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:29:39
   Revision: 08          Serial number: 21001042040A6C
   VCID: 2757E54596F60B6
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 227
                    Mileage: 212022 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:29:05
   Coding: 0000052
   VCID: F4ED420997A0B0E
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Component: EPS_ZFLS Kl.0       1301
   VCID: 2E591061B90C5AE
1 Fault Found:
                    Mileage: 2000 km
                    Temperature: 30.0°C
                    Voltage: 12.70 V
                    Voltage: 12.40 V
   Component:    KSG              0201
   Coding: 00E802087F2D8404084B0100
   Shop #: WSC 00663 202 05755
   Coding: 0000052
   VCID: F5EB7F0D9CDAA96
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Component: Radio RCD310  031 0075
   Revision: 01000001    Serial number: VWZ1Z2L3561318
   Coding: 05000400020001
   Shop #: WSC 00788 648 00255
   VCID: 336F0115922E776
2 Faults Found:
00856 - Radio Antenna
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 162
                    Mileage: 211402 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:01:32
03138 - Input AUX IN
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 162
                    Mileage: 211402 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:01:27
				abdj
- Auto:: 1T3 2.0 TDI 2010
Ja rowniez wkleje moje błedy i z gory dzieki za pomoc
Part No SW: 03G 906 016 A HW: 028 101 073 1
Component: R4 1,9L EDC G000SG 5185
Revision: 12345678 Serial number: VWZ7Z0C8491817
Coding: 0000072
VCID: 214DE1B784ED
1 Fault Found:
16785 - EGR System: Insufficient Flow
P0401 - 000 - -
RPM: 1659 /min
Torque: 36.0 Nm
Speed: 60.0 km/h
Load: 14.1 %
Duty Cycle: 14.7 %
Bin. Bits: 00001000
Mass Air / Rev.: 220.0 mg/str
Mass Air / Rev.: 360.0 mg/str
VCID: 2F69178FC239
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
Component: Bordnetz-SG 1.0 H29 0701
Revision: 00029000 Serial number: 00000000273233
Coding: 00890F000004100000120C000000000000
VCID: 37792FEF3A69
Coding: 16711828
Shop #: WSC 00000
1 Fault Found:
00984 - Left Tail Light (M4)
Component: Tuersteuergeraet 09 0111
Coding: 0000116
VCID: F4E358E3EB9F
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Coding: 0000072
VCID: 214DE1B784ED
1 Fault Found:
P0401 - 000 - -
RPM: 1659 /min
Torque: 36.0 Nm
Speed: 60.0 km/h
Load: 14.1 %
Duty Cycle: 14.7 %
Bin. Bits: 00001000
VCID: 2F69178FC239
1 Fault Found:
VCID: 37792FEF3A69
Coding: 16711828
Shop #: WSC 00000
1 Fault Found:
Coding: 0000116
VCID: F4E358E3EB9F
1 Fault Found:
				abdj
Saksowałem i narazie nie ma bledow ale jeszcze mam ptanie. Dzis vcds-em chcialem uruchomic dogrzewacz. Ale niestety sie nie uruchomil i wyskakuje mi blad przy kazdej probie i blokuje piec
Part No: 1K0 815 071 M
Component: Zuheizer 020 1312
Coding: 0000011
Shop #: WSC 12345 123 12345
VCID: 2F69178FC239
1 Fault Found:
01412 - Glow-Plug with Flame Monitoring (Q8)
Fault Priority: 0
Fault Frequency: 1
Reset counter: 73
Mileage: 208317 km
Time Indication: 0
Date: 2000.00.00
Time: 14:57:56
Start
Temperature: 16.0°C
Temperature: 25.0°C
Ta swieca jest do wymiany czy jakies czyszczenie wchodzi w gre ? Zamienniki ?
Coding: 0000011
VCID: 2F69178FC239
1 Fault Found:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 73
Mileage: 208317 km
Time Indication: 0
Date: 2000.00.00
Time: 14:57:56
Start
Temperature: 16.0°C
Temperature: 25.0°C
- jarry
- Imię:: Rołbert
albo sztyft ci poszedł albo elektronika w piecu, możesz zmierzyć rezystancję sztyftu ale to nie jest proste, metoda Kelvina
				abdj
To juz za grube rzeczy jak dla mnie. za nowym sztyftem chyba sie rozgladne  Jakies zamienniki sa godne
[ Dodano: Wto Wrz 25, 2012 09:27 ]
Wroce do tego mojego pieca. Chodzi o to ze ostatnio wydarłem go z auta i rozpolowilem i zrobilem test vcds-em samej swiecy czy grzeje i swieca grzeje jest goraca jak macałem palcem. Po skreceniu pieca i probia uruchomienia pieca wtedy tylko cyka i nie chce sie zapalic pieci wyskakuje blad plomienia swiecy. Czyli u mnie raczej elektronika jest ok ?
 palcem. Po skreceniu pieca i probia uruchomienia pieca wtedy tylko cyka i nie chce sie zapalic pieci wyskakuje blad plomienia swiecy. Czyli u mnie raczej elektronika jest ok ?-
				gawon99
Scan z VCDs 11.30
Witam. Mam nadzieję że to jest to miejsce na pokaznie scanu z VCDS i uzyskać poradę.
A więc:
VCDS Version: Beta 11.3.0
Data version: 20110801
Thursday,30,August,2012,11:54:19:10074
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 37 42 44 46 52 56 77
VIN: WVGZZZ1TZ7W016469 Mileage: 247100km/153540miles
77-Telephone -- Status: Malfunction 0010
Part No SW: 03G 906 021 MM HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 0511
Revision: --H06--- Serial number: VWX7Z0FN3ND15X
Coding: 0000072
VCID: 76E7E2EB7DE3
1 Fault Found:
000769 - Cylinder 1: Misfire Detected
P0301 - 000 - - - Intermittent
Fault Status: 00110000
Fault Priority: 3
Fault Frequency: 2
Mileage: 246138 km
Time Indication: 0
Date: 2000.00.00
Time: 12:41:40
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.83 V
Inj. Quantity: 2.89 mg/str
Temperature: 78.3°C
(no units): 0.0
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000005947873
Coding: 00890F2100040F0007120C000000000000097B075C0001
VCID: 6CD3C08333AF
Subsystem 1 - Part No: 2K1 955 119 C
Component: Wischer 081106 020 0501
Coding: 00038805
Shop #: WSC 01324
2 Faults Found:
00093 - Terminal 15 for Starting Relevant Consumers
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 23
Reset counter: 57
Mileage: 246138 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
01049 - Supply Voltage Term 50
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 3
Reset counter: 47
Mileage: 246138 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.40 V
OFF
ON
ON
OFF
OFF
Address 77: Telephone Labels: 3C0-035-729.lbl
Part No SW: 3C0 035 729 F HW: 3C0 035 729 F
Component: Telefon 6809
Revision: 00012000 Serial number: 0000000814498
Coding: 0016043
VCID: 2647F2ABEDC3
1 Fault Found:
00992 - Consumption Cut-Off Active
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 246177 km
Time Indication: 0
Date: 2000.00.00
Time: 15:35:45
I co wy na to. Pomóżcie bo z tego nic nie kpw. JEdynie wiem że coś na silniku, coś centralnym (chyba) i telefonem. Jak ktoś pomoże to byłbym wdzięczny.
A i dodam że ostatnio byłem na serwisie VW i nie było żadnych błędów. A co najlepsze ze w tamtym tygodniu byłem u mechera aby sprawdzić przez kompa co jest z autem. Bo mi trochę źle odpala i trochę drżało tak przy 2000 obr/min ale tylko na 4, 5, 6 biegu. No ale sam patrzyłem na jego mały komputerek do diagnostyki i nie pokazał błędów. A błędy są. Aż śmiać mi się chcę. Jednak warto było zainwestować 148 zł aby samemu diagnozować autko.
						A więc:
Chassis Type: 1K0
Coding: 0000072
VCID: 76E7E2EB7DE3
1 Fault Found:
Fault Priority: 3
Fault Frequency: 2
Mileage: 246138 km
Time Indication: 0
Date: 2000.00.00
Time: 12:41:40
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.83 V
Temperature: 78.3°C
(no units): 0.0
VCID: 6CD3C08333AF
Coding: 00038805
Shop #: WSC 01324
2 Faults Found:
Fault Priority: 2
Fault Frequency: 23
Reset counter: 57
Mileage: 246138 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
Fault Priority: 1
Fault Frequency: 3
Reset counter: 47
Mileage: 246138 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
OFF
Voltage: 12.40 V
OFF
ON
ON
OFF
OFF
Coding: 0016043
VCID: 2647F2ABEDC3
1 Fault Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 246177 km
Time Indication: 0
Date: 2000.00.00
Time: 15:35:45
